Checking for spark.....and I'm an idiot
Old Apr 19, 2008 | 12:57 AM
Basstromboon's Avatar
Default Checking for spark.....and I'm an idiot
Having issues with my 83 atc 110. Traded for it...has no spark...Bought a meter to test things (I don't know how to use it) needless to say I am back at square one. Any advice (besides bring it to someone else...lol) I really want to learn how to test to find out spark problems. Is there a certain meter I need if not what am I suppose to put it on and what to expect?
Sorry for being so dumb.....sigh
Any help is appreciated.
Thanks,
Kaven
Old Apr 20, 2008 | 01:11 PM
maggiesboy's Avatar
"One Wheel Short"
no meter needed......
place the plug against the head (with the plug wire hooked up) crank the engine over and watch for the blue spark...... the meter will help you check the coil for resistance, see your service manual for that info.
Old Apr 20, 2008 | 01:39 PM
Yeah I knew I didn't have spark...I had tested that but can't find out WHAT is wrong. Any help?
Old Apr 20, 2008 | 03:47 PM
hondabuster's Avatar
Your best source of help would be the service manual. I would think a local library would have the one you need, or ebay does. There are specific guides in the manual with steps to follow to troubleshoot a no spark condition.
Make sure the switches work..like the key switch and the kill switch.
Old Apr 20, 2008 | 08:37 PM
SMFREY's Avatar
I agree with Hondablaster
Get a manual
I looked in my Clymer M311 manual That the one you need
The tests are simple I was going to do an explain as to the tests but you need to follow illistrations
Need manual
But week spark is usually bad connections
No spark OHM meter
Good luck
Ray
Old Aug 6, 2008 | 01:27 AM
Ended up just giving in and brought it to a local small engine guy. He didn't know anything about atcs but gave it a shot. Come to find out he opened up the crank case to clean out the magneto and found a cut wire deep inside. Fixed that and can shock yourself all day long now. Thanks for the help. With these old things you can never tell.
Best wishes
Old Aug 6, 2008 | 01:55 AM
Sidewinder500's Avatar
lol next time have your buddy hold the plug wire while you kick it over *sucks to be the buddy, but a blast to be the one doing the starting*
Seriously though glad you got it fixed.... happy trails
Old Aug 6, 2008 | 11:58 AM
SMFREY's Avatar
Glad it is fixed
Time to ride
Ray
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Divergent12
Dec 30, 2017 08:33 PM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
DeFox500
Jul 26, 2015 06:32 PM
