Need help with ATC 70 compression issues
Old Aug 31, 2008 | 02:44 PM
notyepcars's Avatar
Default Need help with ATC 70 compression issues
I rebuilt my 82 atc 70 and was running fine, I put the camshaft gear washer on the wrong side, so took it apart to switch it. I have absolutely no compression, if I stick my finger over the spark plug hole nothing. My main qestion is on the valve timing. piston TDC, do you lay the camsaft sprocket with the o mark at 9 oclock or 3 oclock. In turning over my engine by hand it will spark at both locations, need to know proper way to install the camshaft gear and adjust valves, or any other idea of why a fresh rebuild has no compression. Thanks
slowgsxr97
Mar 18, 2022 03:40 AM
manuelrivera
Aug 8, 2015 04:34 PM
NatePerz
Jul 27, 2015 03:27 AM
southbayman
Jul 24, 2015 09:30 AM
ghost civic
Jul 19, 2015 10:13 AM
