350x engine swap
Old Sep 5, 2008 | 01:08 PM
atc350xer's Avatar
Default 350x engine swap
I got an '85 350x with a trashed motor. One of the valves broke off, punching a hole in the piston and destroying the head. That's not the worst part. The previous owner cut off the rear motor mount so I'd need to find a left side case as well. I have found a few on ebay, but they're expensive, you never know what you're getting, and shipping is way high, which brings me to my point. I have a local motorcycle salvage yard here that has a few 300ex's. Will the 300ex motor fit(I'd get electric start and reverse in a 350x!) or is there a better choice? They want $500 for a 2001 motor with all the wiring and carb, etc.
Thanks in advance
Old Sep 7, 2008 | 05:24 PM
atc350xer's Avatar
Please, anyone who might have an answer for me, post a reply!
Old Sep 7, 2008 | 06:10 PM
Black Sheep's Avatar
Yes with minor adjustments the 300ex motor will fit. I think there are threads from those who did it on the 3 wheeler only boards
Old Sep 7, 2008 | 09:14 PM
Cody2's Avatar
Yeah it will work, but did you say you needed new motor mounts?
Old Sep 7, 2008 | 09:41 PM
atc350xer's Avatar
The rear mount on the motor itself was cut off, supposedly to make it fit into a quad, so I'd need a whole new motor or the left side case(where motor mount is) and head. Is a 300ex motor a bolt in, or will it need extensive fabricating?
Old Sep 24, 2008 | 02:39 PM
dbc112's Avatar
I have an 86 motor I am getting rid of. Smokes and needs some TLC. Had it in my 250x for some time, just purchased an 03 300ex engine with national kit.. Hope it fits...
Old Sep 24, 2008 | 05:26 PM
atc350xer's Avatar
where are you located? I'd much rather have the correct engine in my 350x...
Old Oct 6, 2008 | 09:04 PM
atc350xer's Avatar
Gave up and turned it into a parts trike... bought me an '86... I'm in love...
Old Oct 7, 2008 | 02:13 AM
this guy's Avatar
well if you want a future project I have heard a few people putting 400ex engines in them. Nearly the same size and much faster.
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
