ATC70 shifts backwards. why?
I purchased an '84 Honda atc70 a couple months ago that wasn't running and wouldn't come out of gear (what I thought should have been neutral was actully forth). After I got it running I realized it shifts backwards. Any ideas on how to remedy this?
When you say it shifts backwards... do you mean the patern goes 4 down as you progress through the gears? If so, there's nothing wrong with your threewheeler... 81-85ish Hondas were built that way for some unknown reason. You can't fix it because its not broken and all it takes is a little getting used to. My dad's '84 200m is the same way.
