electric starter 83 200e big red
Old Dec 21, 2008 | 11:25 PM
splescort's Avatar
Default electric starter 83 200e big red
83 honda atc 200e
when i got the bike the electric start was not working. it was a wiring issue.
so i fixed that but still did not have a battery so i did not use it. just started it with the pull start.
well i got a battery for my birth day.
when i push the start button you can hear the starter motor spin but the bike motor does not....
what should i do/look for.
today i took the pull start off and the other thing that is held on with three 8 mm bolts then i took off all the 8 mm bolts that hold on the black cover that covers the where the starter slides in to. but i can seem to get that cover off. the only thing that i can see that might still need to come off is the crank bolt.
any ideas
Old Dec 23, 2008 | 12:24 AM
scary132's Avatar
Yea. You have to take that bolt in the center of the crank to remove the plate. Then all the starter gears are exposed.
Old Dec 23, 2008 | 12:27 AM
splescort's Avatar
ok thats what i thought but how go i hold the crank while i take that bolt out and is it normal tread ??????
Old Dec 23, 2008 | 02:04 PM
scary132's Avatar
Should be regular thread, the manual doesn't say otherwise. I made a crank holder out of some scrap aluminum. I drilled a hole in the center big enough for the socket to fit through, then a couple of small holes for the pull starter cage bolts to secure it to the crank. I didn't have an impact at the time. I'm sure that would work too.
While you have it this far apart, might want to check your front sprocket and replace it if needed.
Old Mar 6, 2009 | 06:23 PM
Jeff_85200M's Avatar
put yur ratched on and give it a quick jolt... useually works
Old Mar 6, 2009 | 09:09 PM
splescort's Avatar
i ended up getting a cordless impacked driver for my birthday to and it took it off the first impack of the gun
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Pahuntman
Sep 5, 2015 11:07 AM
oldschool64
Aug 12, 2015 07:13 AM
akbrewcrew
Aug 9, 2015 10:54 PM
raceware
Jul 30, 2015 06:59 AM
