ID problems
Old Sep 17, 2010 | 12:07 PM
Jaster94's Avatar
Default ID problems
i think i got a 1984 250r 3 wheeler. it's definitely a 1984 honda. decoding the VIN is giving me some problems. i've deciphered most of it with the VIN decoder online, but this part, "TB052" i cannot figure out. is it a 250 spelled backwards in the VIN? how can i tell what the CC displacement actually is? how can i tell about the "R" part also?
Old Sep 17, 2010 | 12:28 PM
scootergptx's Avatar
Supersock
Hired Gun!
Without copying all the useless stuff they had posted with this, here's what I could find about that number.
"Your '84 ATC200X should have an engine number
Starting with TBO5E-61xxxxx
'83=TBO5E-60xxxxx
'85= TBO5E-62xxxxx
Frame:
'83=TBO52_DCxxxxxxx
'84=TBO52_EC or EK xxxxxxx
'85=TBO52_FK"
I would guess that is the frame number, but as far as the engine size goes, I don't know about that.
Here's the whole post.
Old Sep 17, 2010 | 01:41 PM
TLC's Avatar
TLC
The 250R ATC was from 81-86, (1981-1984) used an air-cooled, 248cc single cylinder 2-stroke engine used in the CR250 motocross. ('85-'86) used a liquid-cooled, 246cc single cylinder 2-stroke engine also from the CR250 but without reeds.
The 85-86 had a six speed tranny all the rest were 5 speed.
Old Sep 17, 2010 | 04:43 PM
sdm111's Avatar
2 strokes or 4
If I'm reading right you want to know if it's a 250R right? Put up a pic I can tell you if you have a 250r or not. Easiest way to tell is if it has an expansion chamber. Does the pipe come out the cylinder curl around go up the side gets bigger then smaller at the silencer?
Old Sep 17, 2010 | 04:48 PM
sdm111's Avatar
2 strokes or 4
To tell about the R part, you'll know when you ride it. LOL
Old Sep 17, 2010 | 04:50 PM
sdm111's Avatar
2 strokes or 4
The suspense in killing me, 84' was the best year of the air cooled R IMO most sought after around here
Old Sep 17, 2010 | 04:56 PM
TLC's Avatar
TLC
LOL,That a sure sign, if it hits 60mph and is still climbing chances are its a R.
Old Sep 17, 2010 | 05:02 PM
sdm111's Avatar
2 strokes or 4
Yeah and hitting that 60 in about 3 sec.
Old Sep 18, 2010 | 09:44 AM
Supersock
Hired Gun!
There's always the arm test.
Measure your arms before you ride. Hope on an hit it wide open through all the gears. Measure your arms again. If they're about 5 inches longer, you know you got the R.
Old Sep 18, 2010 | 12:57 PM
Jaster94's Avatar
Default this trike
ok, looks like according to your posts, i've come to the conclusion it's a 200X. man this thing is rough! it was a parts trike for a while in a backyard. don't know what the future holds for it yet.......thanks for the help!
Attached Thumbnails ID problems-102_4548.jpg   ID problems-102_4549.jpg   ID problems-102_4550.jpg   ID problems-102_4551.jpg
