atc350x engine questions.
hey guys i have been kicking around the idea of a 10.25:1 piston, a web cam probably the 180 grind number
valve lift .350/.350
duration 252°/252°
duration @ .050. 228°/228°
or the powroll cam (doesn't have specs) what cam would you use?
i will probably do mild port work and i was thinking of the 40mm mikuni hsr carb i would like to get your guys opinion on the carb also.
i know its hard to say but it would be nice to have in opinion on the hp numbers.
duration 252°/252°
KimSJoh
14
Jul 18, 2015 07:20 PM
