Fuel problems
Old Jun 9, 2013 | 12:13 AM
3wheeler762's Avatar
Default Fuel problems
I have a yamaha 125 3 wheeler I think it's between 79-81 could not find a year on the trike but its not getting fuel. there is fuel to the carb and I just cleaned and completely blew out the carb. it runs If I pore gas in the cylinder until that gas burns off. Does anybody have any suggestions to fix this problem.
Old Jun 11, 2013 | 06:46 PM
mudmike's Avatar
Sounds like either the float is out of adjustment, or that you still have a jet/passage blocked in the carb.
Old Oct 14, 2013 | 09:08 PM
kormos_93's Avatar
I would be willing to bet your main jet is still plugged (large jet directly under the slide needle) You should be able to hold the carb up without the slide on it & see light through it. Very tiny hole, easy to miss.
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
