83 big red new carb revs high
Old Apr 27, 2015 | 02:27 PM
Mikeyeager's Avatar
Default 83 big red new carb revs high
I am trying to get my grandpas old three wheeler running it sat inside for about 15 years then outside for anouther 5 years without running and was running when stored pull start is stuck and electric start button won't work however I can hook jumper cables up to car battery and touch the post on starter and it will turn over and has good spark I put in a new spark plug and cleaned carb and wouldent run I then bought a new carb off ebay and put it on. Now it will start and run with choke on and seems to sound real good however when I push choke button in it revs real real high also nothing seems to change when I hit the throttle
Old Apr 27, 2015 | 06:26 PM
Could be sucking air,jetting could be too lean.On something this old,setting up this long,just start at the basics,change oil,plug,check/adjust valves. An old manual can help you in more ways than one. See if these free ones still work. ATC Manuals
Old Apr 28, 2015 | 05:03 PM
Mikeyeager's Avatar
Ok thanks Do you by chance know if rear rims off a yamaha 3 wheeler will go on honda 3 wheeler
Old Apr 28, 2015 | 05:14 PM
Nope,don't know,but someone else may come along that does..
Old Apr 28, 2015 | 08:50 PM
Mikeyeager's Avatar
One more quick question do you know if I could take rear end out of honda three wheeler and put it on yamaha 3 wheeler
Old Apr 29, 2015 | 10:02 AM
Wouldn't think so,not with out a lot of fabrication work. Just try to repair/replace with what you have rather than trying to cross breeds parts.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
