350x sprocket swaps
Old Jun 7, 2002 | 10:09 PM
Jimster's Avatar
Has anyone swapped the sprockets on a 350x for higher gearing? I want to buy some 18" turf tamers for my machine. I realize this is going to lower the gear ratio & make it even harder to keep the front tire on the ground. But even in stock form, the 350x seems to be geared to low for me. In stock form I think I need about 20% higher gears, now that the tires are going to be 20% smaller, I'm thinking I need about 40% higher gears. Does anyone know what combination of gears I would need & how to figure out the new chain lenght?
Jim
Old Nov 26, 2002 | 12:54 AM
Megaman's Avatar
Default 350x sprocket swaps
I have a 85 350x with a 14T sprocket on it. It lost lots of lowered power, due to the teeth, but has much more top speed. I would try the 14t sprocket. It should help alot.
Old Feb 25, 2004 | 09:04 PM
LittleBehaus's Avatar
Where did you find the 33 tooth back sprocket. I got a 35
but would like to have a smaller one because
I want more top end for my 350X. In other words I want to be able to beat a Predator.
I'm almost there, but I need about 10 mile an hour.
'86 350x
pipe
k&n
bigger front and smaller back sprockets
bored .40 over with wiseco dome top
cam and carburetor on the way
Old Mar 1, 2004 | 12:44 AM
KI6HNB's Avatar
A 14 tooth front and 35 tooth rear should get you where you need to be. Call TC racing for a hi rev CDI box. www.tcracingengines.com
Old Mar 17, 2004 | 09:59 PM
hey you never did tell me where you found the 33 tooth sprcket?
buddieboy
Dec 9, 2016 05:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
