350x exhaust
Old Feb 10, 2003 | 03:03 PM
ALdarkcloud36037's Avatar
Default 350x exhaust
i have heard that you could use a 400ex header on a 350X, i know it will bolt up to the head, but is cosiderally longer. does anyone have any info on this modification
Old Feb 11, 2003 | 01:30 PM
Deeve7's Avatar
The 400ex headpipe will fit on the 350x head, but I'm not sure how it will match up with the silencer on the 350x frame. Most people use the 400ex pipe on the 350x when they have them installed in quad frames. I have a 400ex pipe on my 350x in a 250x frame.
Old Feb 11, 2003 | 04:26 PM
thanks for the info, i wonder if the bend is the same. maybe someone will know
Old Feb 11, 2003 | 04:58 PM
Deeve7's Avatar
The bend seems to be close, but not quite the same. I am guessing you would have to fabricate a small piece of pipe to connect the head pipe and silencer. You might be better off getting some kind of aftermarket headpipe for the 400ex to get close to the correct bend that you need. If you compare pictures of both they are pretty close.
Old Feb 11, 2003 | 06:16 PM
i was just wondering about it, i know they are longer, the by the frame looks a little different, you got any tips on getting out those old exhaust studs, i would like to replace them, but scared to try to get them out, might break, any tips
Old Feb 11, 2003 | 06:31 PM
Deeve7's Avatar
I haven't tried to replace the exhaust studs. I would guess a torch and maybe some liquid wrench with the use of some small vice grips. Mine seem to come out when I don't want them to and then strip out when I go put them back in. That's the thing to be careful with steel and aluminum don't match up too well.
Old Feb 12, 2003 | 01:35 PM
yea, one of mine is bent, and the other three i think is cross threaded, the guy that put my motor back on the frame used different bolts, smart huh, he even screwed up all the motor mount bolts, got to get those too, i recon ignorance and wrenches dont mix
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
