200X locked up
Old Feb 26, 2003 | 07:03 PM
4wheelr220's Avatar
Default 200X locked up
OK, it died while I was riding at a real slow speed, the kickstart lever jerked back up like it would if your foot were to slip off but it was already all the way up. I tried to kickstart it and the kickstarter wouldnt move. I assumed the piston seized and loaded it up and took it home, so last night I took it partially apart. The piston isnt siezed but for some reason the crank will only turn about 2 revolutions then it "catches" on something but if gently forced it will keep turning but it seems like its trying to shift into gear. The shift shaft is seized in the position that would be all the way down when going from neutral to first. So what does everyone think is wrong, could it be the kickstart gear gave up in the motor or something to do with the shift forks/drum?? Also, where would I get the socket to fit the nut on the clutch, and what type of puller do I need to pull the flywheel off??
Old Feb 27, 2003 | 12:38 AM
hrc200x's Avatar
I thought I heard somwhere motionpro had the socket, if not try honda. as for the flywheel puller, remove the swing arm bolt and use that. If the bolt is rusted in the front axle might be the same but don't quote me.
Old Feb 28, 2003 | 03:42 PM
AlkyBurninX's Avatar
You've experienced hondas troublesome 83-84 200x tranny lockup problems. Third gear gets worn and slides into 4th!
Old Mar 3, 2003 | 05:30 PM
4wheelr220's Avatar
So, what all will I need to replace??? I havent got that far into the motor yet so I dont know what all gears are messed up, can I just replace the 3rd gear pieces or do I need more of the tranny???
Old Mar 4, 2003 | 08:21 PM
There is no telling until you get in there. A piece of gear could have got lodged in between other gears and chipped them.
greg74
Sep 10, 2019 03:03 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
