is a honda 70 three wheller engine same as trail70
Old Apr 18, 2000 | 10:42 PM
nikbrew's Avatar
i want to know is a honda three wheller engine is the same as a trail 70. The reason i ask is cause i have a QA 50 and i know a honda trail 70 engine will bolt in, want to know is a three wheeler engine would bolt in too.
Old Apr 20, 2000 | 03:05 PM
b(250rman)'s Avatar
I think the atc 70 has different trannyu ratio's then the trail 70 I have a SL70 and it has a clutch and the atc 70 doesn't I used to have a atc 70 and it was ok for a smaller guy or gal but I think with the trail 70 motor the ratio's will only make it worse. WELL REMEMBER u CAN PRACTICE PRACTICE AND PRACTICE AND u STILL CAN'T BEAT ME
Old Apr 23, 2000 | 02:08 AM
NewDuneRider12's Avatar
The ATC70 engine is very similar to the SL70 engine, one point to note is that the crank is different 'cos it has to accomodate the zip starter.
I have a Z50 which I grafted on a head and barrel from an atc 70, it works fine. I'm sure you will find an ATC70 shoud just bolt in to your QA50 frame.
How about this for a twist. I know a guy who grafted a 200X engine into an ATC70 frame. I may have a photo somewhere if you are interested. By the way, this was not just a bolt in swap, the engine needed radical modification to make it fit but stangely enough the frame remained almost standard.
hugemoth
Jul 20, 2020 03:28 AM
Scottma518
Jul 16, 2015 09:19 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
MNatv89
Jul 7, 2015 11:36 AM
