250r swaybar setup
Old Aug 3, 2003 | 08:15 PM
cheesedog's Avatar
Default 250r swaybar setup
I was wondering if any one could help me setup and dial in my durablue sawbay bar for my 250r? I race TT and not to sure how to dial it in? Any help would be greatly appreciated. Thanks.
Old Aug 3, 2003 | 09:58 PM
FTZLT250r's Avatar
Some people go by feel and some use 4 scales. You set the quad on 4 scales and look at the weight on each scale. You can start there by setting it up with a neutral set up. Run it and see how it feels. Then do it again, and jack weight where you want it.
Old Aug 4, 2003 | 10:02 AM
Chawness's Avatar
Back in the day, I used 2 regular bathroom scales, one under each rear tire. Adjust each side of the swaybar to obtain the desired weight on each rear tire (usually equal). Once you make the adjustment, push the suspension down a few times and recheck it.
Other things can help the grip of your quad too, such as tire compound, air pressure and axle width.
Old Aug 4, 2003 | 10:18 AM
LT80's Avatar
LT80 Expert
Using 4 batroom scales is the only way to know exactly what's going on,but if you dont have,or dont want to buy them:::set the sway bar so the mounting bolts slide through the holes without pulling or pushing the machine up or down.Then lengthen the right slightly (1/4 turn). This will be close,but not exact.
Have fun
TT rules!
Old Aug 4, 2003 | 08:05 PM
cheesedog's Avatar
thanks forur hellp guys. i just bought four scales and will set it up tonight! will let you know on how it felt once again thanks
Old Aug 6, 2003 | 06:12 PM
AlkyBurninX's Avatar
I use scales to set my front shocks and level them. I just use the track conditions to adjust the swaybar. I am running almost neutral.
Old Aug 7, 2003 | 09:54 AM
LT80's Avatar
LT80 Expert
How do you know if you are running nuetral w/o scaling all 4 wheels at the same time?
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
jbrewster94
Sep 23, 2015 04:16 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
