LRD 250r Frame
Old Aug 13, 2003 | 05:20 AM
86trx250rhonda's Avatar
Default LRD 250r Frame
What do i have to change from a 86 trx r frame that has been modified to 89 style(motor mounts and swing arm) to make it work or will every thing just bolt on. I'm pretty sure i would need a 88-89 style grab bar. What other little thigs do i have to do to make everything go together? Thanks Skyler
Old Aug 16, 2003 | 12:25 AM
WP's Avatar
WP
Call them and find out.
Old Aug 16, 2003 | 03:17 PM
Duncanracer's Avatar
the only thing you ahve to have is the 88-89 style swing arm....
Old Aug 18, 2003 | 01:33 AM
I already have the 88-89 swingarm(solid) no space like 86-87.
Thanks
Old Aug 18, 2003 | 01:43 PM
then everything shouold just bolt up...
Old Aug 20, 2003 | 01:34 AM
Brad_L's Avatar
I don't know what kind of nerfs you have, but if they go through the chassis like mine did (new style AC propegs) then lookout. I had serious problems making mine fit. What I finally did was use a pipe bender to make an S bend in the nerfs so they could go through the frame at a more forward point.
Most everthing bolted up, but just remember that if you have anything that mounts around the frame you may have problems due to the LRD frame being so much larger in diameter.
The three things I had problems with were OMF radiator shrouds, AC nerfs, ESR CR ignition coil mount.
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
