What mods can i do to my mojave to go faster
Old Nov 14, 1999 | 01:42 AM
Mojave87's Avatar
I would like your opinion on what i can do to my mojave to get more top end and low end power i do a lot of wide open riding and jumps and woods riding.
Any help is appreciated!
Thanks!
Old Nov 14, 1999 | 02:11 PM
hot_shoe_cv's Avatar
Mohave87, Knowing absolutely nothing about Mohaves,I can't be very specific, but two things that are basic to any machine for improving performance are adding an aftermarket pipe and improving the air input to the carb., either by an aftermarket filter if one is available for your ride, and/or by drilling out your air box cover to allow greater air input. Of course in doing any of these things you'll have to re jet to compensate fot the larger air flow. To greatly increase performance across the entire band would probably entail engine work involving considerable expense, altho the above air modifications will definitely make a difference. Most pipes are built to help performance either at the low end or mid to high end, but not both at the same time. Some however, can be tuned by the user for a more or less specific part of the band. Such a pipe is the Supertrapp IDS system, or the FMF, I believe.
Gearing up or down can affect you power band too, but again, only one end or the other.
These are all bolt on modifications costing relatively little compared to engine kits, but will give you noticable improvement while maintaining the reliability of your bike.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 11-14-1999).]
Old Nov 14, 1999 | 07:17 PM
Mojave87's Avatar
Would anyone happen to know where the airbox lid is on my mojave.
Old Nov 14, 1999 | 10:42 PM
mudman's Avatar
i believe that the access for it is on the left hand side of the machine right below the seat
Old Nov 15, 1999 | 05:16 PM
Mojave87's Avatar
I found that lid but now i need to know where to drill my holes and how many holes to drill?
Old Nov 24, 1999 | 03:31 PM
Tranz455am's Avatar
Doesn't Mickey Dunlap do Team Kawasaki's Mojaves?
95 Warrior 95 XR250 97 Kodiak
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
