Suspension question
Old Aug 6, 2005 | 09:35 PM
Warrior13's Avatar
Default Suspension question
Does anyone one know that if I tighten up the suspension on my Warrior will it work better for bigger jumps?Because right now I go off a medium-sized jump and it almost/sometimes bottoms out.I wieght 145 lbs.
Old Aug 6, 2005 | 10:03 PM
clover's Avatar
Yeah it should help you from bottoming out,i just went to the track today on my kfx and i have my suspension tightened about half way and it soaked up the smaller stuff really well,but over some of the bigger jumps i still bottomed out a few times.
Old Aug 6, 2005 | 10:04 PM
Warrior13's Avatar
ok thanks
Old Aug 6, 2005 | 10:27 PM
Warrior13's Avatar
I dont think I have the right tool.What tool can I use to rotate the Cam?
Old Aug 7, 2005 | 01:28 PM
clover's Avatar
Yeah you have to have some special wrench from the dealership,but i did mine with a small metal like rod and a hammer and just kept knocking it around tighter.I've heard you can use channel locks also.
Old Aug 7, 2005 | 06:38 PM
Warrior13's Avatar
yeh I just used 2 channel locks.But I think I need better suspension or maybe just go off jumps with a landing because the springs are as tight as they can be and will bottom out after going off a medium-sized jump.I think its just that the springs are so old that they just got soft.My warrior is a 1999.
Old Aug 9, 2005 | 06:44 PM
drag101's Avatar
i have rly soft suspenstion on my 300ex and i never buttom mine when jumping it
Old Aug 9, 2005 | 06:48 PM
paintballbanshee's Avatar
how much do u weigh?? i dont bottom out on my warrior and im 145..
Old Aug 10, 2005 | 09:16 AM
Warrior13's Avatar
i weigh 145 lbs also.I think just my suspension is soft.Soft meaning its old.
Old Aug 11, 2005 | 04:37 PM
TexasRaptor's Avatar
You need to use a "spanner" wrench so that you don't tear up and scuff your shock adjustment cam.
You can get them cheap at Harbor Freight or Northern Tool.
1ArmBandit
55
Oct 14, 2015 09:03 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
chewy78
Sep 8, 2015 10:37 AM
