Recon exhaust and suspention question
Old May 6, 2006 | 01:17 PM
  #31
spit's Avatar
Default Recon exhaust and suspention question
Yes the stock snorkel shaped like an "S" take that out make sure the vaccum hose is the same size as the part of the "S" shaped snorkel that was inserted in the air box and then just clamp on the vaccum hose.
04 Honda Recon ES
lots of race mods
Old May 6, 2006 | 01:56 PM
  #32
hillclimbingrecon's Avatar
sounds easy,are there any sideeffects i should know about?
Old May 6, 2006 | 11:20 PM
  #33
spit's Avatar
When you install the air box snorkel make sure you leave enough room so you can turn the handlebars without hitting the snorkel,and make sure you make some type of bracket to attach to the front rack to hold the snorkel still up front cause if nothing is there to support it it will flop around.
04 Honda Recon ES
lots of race mods
Old May 6, 2006 | 11:30 PM
  #34
Have you cut your recons plastic?if so cpild you send me a pic?
Old May 8, 2006 | 02:06 PM
  #35
spit's Avatar
I didnt cut any plastic off mine,not yet,but i want to.
04 Honda Recon ES
lots of race mods
Old May 8, 2006 | 04:30 PM
  #36
what were you planing on cuttin off?
Old May 9, 2006 | 09:26 PM
  #37
spit's Avatar
I was thinking of trimming back the parts of the rear fender that hang down like mud flaps.
04 Honda Recon ES
lots of race mods
Old May 9, 2006 | 09:39 PM
  #38
Oh,i was thinking of cuting the front to make it look like a 250r
Old May 9, 2006 | 11:05 PM
  #39
spit's Avatar
You could make your recon look like a 300ex by removing the headlights and headlight panel , just take out the screws holding the headlights and headlight panel, the screws are attached to the bottom of the front fender and the wires going to the headlights have a spot where you can unplug the all 3 the wires.The 3 wires that unplug are the high beam,low beam and off.and they are held by a little bracket just on the left side of where the rack comes through the plastic.
04 Honda Recon ES
lots of race mods
Old May 9, 2006 | 11:12 PM
  #40
would i have to cut the plastic?and would the front move around? Because when i took off the front rack the front plastic whould shaske from let to right and up and down
