Hill jumper please reply
Old Jun 12, 2001 | 09:08 AM
braff1's Avatar
When jumping hills I know that if you want the front end to come up you rev the engine. To bring the front end down you use the brake. My question is which brake front or back?
Dan
Old Jun 12, 2001 | 06:46 PM
mdegain's Avatar
You use the back break. When you rev it and that rear tire spins, the centrifugal force brings the rear end down. When you hit the back brake, the force stops, lowering the front end.
Old Jun 13, 2001 | 08:33 AM
braff1's Avatar
Thanks Mdegain for the tip I hope it helps me with my landings which can be scary at times.
Dan
Old Jun 18, 2001 | 04:55 PM
MXBUBS's Avatar
you can use the front or back brake, the front brake i find works better, but the back brake is usually easier to hit....when jumping, it is important to study the take off.....a steep take off, esp. a short one, will pre-load your front shocks, which will dip your front end on take off, (imagine hitting a brick wall in a truck doing 60mph, the front end smashes down, while the back end will jump up) the faster your are going on any take off, the more downforce you will have on your front end during the climb up the face, if the face is long, like say 9 or more feet, your front shocks have time to rebound, meaning your front end will come back up to almost normal ride height, when this happens, you have to let off the gas to keep it down.....my rule of thumb is, short face jumps, be on the gas hard, long take offs, let off the gas just as im leaving the lip...always be prepared if your bike should depart, meaning, do something you dont want it to do, if you short a double, be prepared to bail off the side, making sure you dont brake your ribs on your handle bars, if it gets sideways, be prepared to hold on to ride it out, or ditch it if you think it is going to go flipping......but most important, be sure you have someone filming!
dannytas
Sep 26, 2017 06:31 PM
EIF
Apr 20, 2017 07:15 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
