few questions on exteneded a-arms
im not familar with exteneded a-arms and i have a few questions. first, when you get yur a-arms, are the shock mounts in the same place as the stock ones? and when you buy yur new shocks, are they longer or are the just stiffer for the extra leverage you have now. because if there the same length and just stiffer i think i might just order the shocks now and buy the a-arms next spring or something. well thanks
LBZ, Works shocks valves theirs for the A-Arms and weight. I have Works for stock arms, and now I can't keep the frame off the ground with LSR +2's. When you get the a-arms, the shocks will bolt right up. Simple as pie.. or is it Pi? (3.14)
Quadzilla Heritage
Sep 25, 2015 01:39 PM
