Theres gotta be an easier way to do this...
Old Feb 16, 2002 | 12:26 AM
Shift's Avatar
How do you guys adjust Custom Axis front shocks? Mine aren't Compression or Rebound Adj. so I can't just turn the little ****. Instead you have to pull the spring down then slide the circlip down into the next groove... a royal pain in the ***... Is there any other way to do this? Like a spring compressor or something?
Old Feb 16, 2002 | 01:02 AM
YoDaddy's Avatar
Do you not have a shock wrench? Most companies give them to you when you buy their shocks.
Old Feb 17, 2002 | 01:04 PM
Shift's Avatar
They [Custom Axis] didn't give me one. All they did give me was some stickers and a technical manual that doesnt explain how to adjust them, it just explains how they work.
Old Feb 18, 2002 | 11:34 AM
retro's Avatar
It sounds like they are only preload adjustable. You should set the sag for your weight and leave it. If the valving or springs are wrong you need to do something about it(like have them revalved or get different springs).
ERIC
Old Feb 18, 2002 | 08:17 PM
adamsmith's Avatar
Get the bike up on a stand that will allow the front tires to be suspended. That will make it alot easier on you. The difference between adjusting sag with the quad on the ground and on the stand is night and day.
Adam Smith
99 400EX
02 CRF450F
35dodge
Sep 29, 2015 09:40 AM
Ahtatu
Sep 28, 2015 12:14 PM
Hack714
Sep 26, 2015 08:11 AM
Irishman301
Sep 23, 2015 01:47 PM
Halffast17
Sep 11, 2015 02:30 PM
