Good atv
What kind of riding will you be doing? Mud, Sand, Trails, Climbing, Rocks, do you need 4wd? Do you mind a manual clutch? do you want to shift gears? do you want a fully automatic? what size bike? will you ever carry a passenger? will you be camping? well you get the point, can you be a little more descriptive on what you want to ule it for?
I know it will have to be used. I was looking at the honda 300ex and the yamaha banshee 350 and warrior. I don't need 4wd. I do not know if I want an automatic or manual I've never ridden before. I would need it to go through sand, water, and mud mostly trail and ditch ridding.
Both the quads you formentioned are good starter,s.If you go with the banshee keep a tite leash on it.It can get out of hand real quick.As for automatic or manual,The automatic is good but you may get board of it after a while.The manual can do more things after you learn how to use it.
Good luck.
Good luck.
Any of them are great machines. I think that for a new person a 300EX is perfect. Warriors are great, I just think their steering feels heavier, and it doesn't shift as smooth as a 300EX.
If you ride in the sand then you must own a Banshee. Be prepared to rebuild it, because generally if you pick up a used one for $3K, it is because it is close to a rebuild, and rebuilding takes 2 of everything. (Twin cylinders means money).
Those are generalizations, and you may find one which is perfect, just be cautious.
A 300 is great as they are generally reliable, and with minor maintenace, they shouldn't be in the shop, only out on the trails.
RM
99 400EX 95 Scrambler 400 85 LT250R
[This message has been edited by rennym (edited 09-21-1999).]
RM
I don't know if I would recommend a banshee as a first bike. They are pretty wild machines, and in the hands of a person new to the sport can give an overconfident feeling. This power along with other riders saying what a powerful quad you have may make you try and do things you probably shouldn't try. I live by one rule: If I stop and question if I can do it, I don't even try it.
Just a suggestion.
Just a suggestion.
I wouldn't worry, I am sure that he can quickly figure out what is safe and what is not. I am NOT a sport person, so I've never really examined the quads you guys are mentioning. I am sure that even a new rider can easily get used to a new quad. Just because you have all that power doesn't mean you need to use it!
[This message has been edited by DreamofPolaris (edited 10-10-1999).]
