Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Which ATV can fit in the Box of Full Size GMC Short Box
Old Mar 31, 2006 | 06:36 PM
v2rider's Avatar
Default Which ATV can fit in the Box of Full Size GMC Short Box
I cant think of what to say to dissagree with you this time
Old Apr 1, 2006 | 06:22 PM
Dirtydude's Avatar
A little bit of doing will cure a whole lot of askin
Old Apr 1, 2006 | 06:45 PM
rooch's Avatar
Curdog,you could always get a deck that straps in your box the new made for short boxes are pretty slick and you can still tow a trailer and have all that storage underneath for all your gear and gas
Old Apr 1, 2006 | 07:06 PM
oper2nyst's Avatar
my eiger[which from looking around is a pretty run of the mill, mid- sized quad], is around 86"over all length[give or take an inch], so thats around a foot longer than you have. the tool box complicates things further[if you want to retain it while carrying the machine. a possible solution [reasonably inexpensive, and not complicated] would be an inclined sheet of 3/4" ply[properly supported underneath], would go over the tool box[obviating its use while the quads in place, could be hinged and supported from below to allow access to box when quad unloaded, sure you could figure it out], but would effectively work. chock the wheels, strap it down and your down the road.....like a mini car transporter
Old Apr 1, 2006 | 07:21 PM
  #15
oper2nyst's Avatar
Originally posted by: Dirtydude
"A little bit of doing will cure a whole lot of askin"
.........are you plagiarizing, or did you think this up yourself? somtimes a "little bit of askin' can save a whole lotta doin' ".........
Old Apr 1, 2006 | 08:22 PM
  #16
RSeb's Avatar
My '05 Rubicon barely fits in the back of my '96 Chevy with the 6 1/2 foot box. I have to back it on and lift the front end a little to get the tailgate closed - but it works.
Old Apr 2, 2006 | 02:40 PM
  #17
Curdog's Avatar
I went forward and accepted delivery on a 2006 King Quad. It appears to be about 2" too long due to a filmsy plastic radiator guard on the front end. I lack about three inches from latching the tailgate. My plan is to lift the front end with a couple of 2x6" to see if tilitng will allow sufficient space for the tailgate to close. If not I'll put the tool box back in and figure a way to ramp the quad on top of it.
I appreciate great advice and commentary, but it appears my fears are confirmed; the new, larger models are a bit long for a short bed full size truck. I find it interesting that the manufacturers do not consider this in either their design or their marketing.
I will likely trade the KQ for the first 600-700 class ATV that fits in the back of my short box without modification or tinkering.
Old Apr 5, 2006 | 10:19 PM
  #18
Curdog's Avatar
Those looking for a convenient but spendy way to support their tailgates at a 45 degree angle should check www.vehicle-systems.com. They make a nice tailgate latch.
Old Apr 7, 2006 | 12:05 PM
  #19
CrownKing's Avatar
That looks like a pretty good idea.[
Old Apr 9, 2006 | 01:48 PM
  #20
Curdog's Avatar
I purchased a set and they came yesterday. They look and fit great but after inspecting them closely, the price seems a bit steep.
