Should i buy, Warrior 350, or Lt250r
So here's a little background, i'm 17 and i'm fairly experienced on atv's and i'm looking for something fast and dependable, i actually learned to ride on a warrior, I'll mainly be riding in the desert some dunes but not often, for awhile at least, and i also plan on doing some jumping, not no 50ft jumps but just some basic maybe 6-7 feet jumps, now i have access to a 1992 lt250r the guy bored it to 310 and he said only things stock are the seat plastics and headlights he claims motor was recently rebuilt, but what scares me is it being bored to 310 might be a ticking time bomb, and ik the lt will likely go 20mph more than the warrior top end, but come in, how often will i be pinned in top gear? Now would i have to do any upgrades to a stock warrior? Also one thing that makes me lean more towards a warrior is parts are much more widely available than the lt, also i have no experience with 2-strokes, i can afford to pick up a warrior now, or wait for my next check in two weeks and pickup the lt for 1300, any opinions is greatly appreciated!
They are fairly simple, much simpler than a four stroke. And plenty of help on the forum.
Kk thanks man! Also the guy claims he has done 50-60ft jumps on it witch means probably pretty beat, any tips on how to check and test the suspension to make sure it's still in good condition?
As mentioned 2 strokes are quite simple but do need maintenance often when compared to a 4 stroke. When my sons ran quads, almost every other year was a cylinder refresh, gaskets etc and then mixing the oil at the correct ratio unless you want to trust the injection system.. With my 4 stroke I just gas and go with an oil change once a year. Sounds like the 250 was run hard and played hard, would not be a candidate in my book but then I am considerably older than you and have different ideas on how to spend my money. Warrior is a good bike, lots of parts availiable, good reputation and will probably cost less in the long run if it is in good shape.
Your call, your money....just my two cents that's all..
