2018 grizzly 700 or 2018 king quad 750
My jeep will be paid off in March, my brother is gonna buy my 2015 foreman from me on the same month. Im curious to see what everyone thinks between these 2 quads. Drag race? Durability? Gearing with 27s or 28s? Maneuverability? Hills? Side hills? I don't think either one of them have changed much in the last 3 years or so, hoping there is some info out there... thanks in advance
The King Quad's engine is only 14cc bigger than the Grizzly, not 50cc like you may think, and they're both DOHC single cylinders. At 666 pounds the King Quad is 26 pounds lighter and the power to weight ratio is a bit higher. Grizzlies have been good all around quads for years and unless something changed they still are. As for specifics, I haven't ridden either one and can't tell you much.
They're both so similar its hard to say which one is better. Even the controls are almost the same, such as the buttons to engage 4x4 and diff-lock. I'd check both of them out and go with the best deal.
It's a tie in my mind. Both of them, as said, use the same type of 4wd system with 2wd, 4wd (limited slip front) and 4wd locked (press of a button, and move the 4wd lever one more notch after 4wd). Similar ground clearance numbers, widths, and lengths. Try both out and see which you like better.
