Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Aeon 90cc
Old Nov 16, 2001 | 08:50 PM
ATV90boy's Avatar
would a Aeon ATV be good for a 12 year old because his friend has a Suzuki Quad Sport 80 and he wants something faster would the Aeon 90 go faster and how fast does it go?Thanks.
Old Nov 17, 2001 | 11:45 AM
raptor720's Avatar
Specifically, I would never tell anyone to buy the Aeon.
Kasea is the best looking and best performing youth atv on the market. Currently 50 and 90cc atv’s s are marketed by Suzuki, Eton, Polairs, Aeon, Sundiro, T-Rex, Jehm, Kasea, Bombardier, Husky, Extreme Machine, Artic Cat, LEM and other manufacturers. Of the many atv manufacturers, Kasea offers features that go beyond the “other guys.” Virtually all of the youth atv’s are equipped with fully automatic CVT transmissions and a 2 stroke oil injected engine, the features that make Kasea superior to other youth atv’s begin here:
Front suspension
The Kasea front suspension is much stronger than that Eton, Polairs, Aeon, Sundiro, T-Rex, Jehm, Kasea, Bombardier, Husky, Extreme Machine, Artic Cat, LEM and some other manufacturers. The Kasea uses a double clevis style knuckle holder rather than the more common single holder. We believe that only Suzuki uses the same strong design as Kasea on the front suspension a-arms.
Rear suspension
The Kasea has the strongest youth atv rear swing arm and axle design on the market. It is a copy of the trusted design used by Yamaha on their performance atv’s since the early 1980’s. No other youth atv has this strong of a rear suspension – it is simply the best. Many of the other youth atv’s don’t even offer a true sport atv style rear axle. We have found most youth atv’s have a rear axle that is a thin metal shaft covered with tubing. Not only is the tube covered design weaker, it allows water to easily enter the carrier bearing area. Other youth atv’s such as the Suzuki LT-80 and an Eton atv model do not even use a traditional rear swing arm. They elected to make the engine and transmission serve as the rear swing arm. The Suzuki and Eton design causes handling problems and is very difficult to modify for increased performance. On the Polaris and a few other models, the rear swing arm, although slightly longer, is too weak for us to consider adequate.
Shock absorbers
Kasea built their atv’s with true rebound dampening Showa shocks that also feature compression preload spring adjusters. The only other youth atv that we have found that has a similar rear shock is Bombardier. Not even Suzuki has a good rear shock. This is a very important safety feature that is often overlooked. When the Kasea is ridden over a large sudden bump, the rebound dampening helps prevent the atv from “bucking” forward as the shock returns to its normal height.
Braking system
Kasea offers a traditional rear foot brake in addition to the front hand brake. This will allow your young rider to learn the proper use of hand and foot controls so they will be ready to advance to a full size atv with a manual clutch without relearning their riding technique. Some models such as the Blazer and Bombardier use full size levers that are hard for little hands to properly grip. We will point out that the T-Rex has a rear disc brake but we feel that the drum brake in the youth market is sufficient for even racing needs.
Optional lighting
We believe that only the Kasea is equipped with a 80 watt lighting coil and is pre-wired for lighting from the factory. All you need to do is purchase the Kasea lighting set that is found as standard equipment on the Kasea 150 atv or simply mount your own lights to the existing wiring. The key switch uses a third position to turn on the lights. Kasea even pre wired for a rear safety light and lighting for your whip antenna. No other youth atv on the market has this much lighting capability. If you want to add lighting to the Suzuki LT80, you will need a special electrical stator and wiring at a substantial cost. LT80 lighting kits that run off the battery only will result in a dead battery and a long walk home.
Starting
Kasea, like most other youth atv’s, offers electric starting with a manual back up kick starter and a fully automatic choke. Kasea studied the other atv’s and took the ease of starting one step further. They added an automatic fuel valve. When the engine starts, the fuel is automatically turned on. When the engine stops, the fuel is automatically shut off. In comparison, the Suzuki and LEM have manual chokes and all other youth atv’s have manual fuel valves. We also note that if you want to add a manual back up starter to the Suzuki, it is a pull rope recoil starter that will cost an additional $80. In the unlikely event that you ever need a replacement electric starter for the Kasea, it will cost about $50 and can be installed in 5 minutes. The Suzuki starter costs about $250 and will require hours of labor to complete the installation.
Rim sizes
Here, you can easily install replacement rims of your choice! The front hubs use the common 4/110 bolt pattern (Honda) and the rear uses the common 4/100 bolt pattern (Blaster).
General Parts
Since most of the youth atv engines are similar, finding parts is usually not a problem. If you need gaskets, air filters, batteries, spark plugs, chain, tires or some basic engine components, the Eton, Bombardier, Polairs, Aeon, Extreme Machine, Sundiro, T-Rex, Jehm or Kasea will interchange. The Blazer, T-Rex, Bombardier and Polaris have a longer drive belt and side case cover though.
Performance
From an aftermarket standpoint, I have the performance modifications for your youth atv. As your child grows, so will his/her ability to control more power. Instead of placing your child on a larger atv that can be dangerous for a younger rider to properly control, modifying a youth atv will provide the challenge that your child desires. I have replacement large bore cylinders, ported cylinders, custom billet aluminum cylinder heads, special over range transmissions, custom exhaust systems, performance carburetors, performance reeds, lighting kits, ignition systems, extended swing arms, wider a-arms, shock absorber kits and various tire and rim options.
Old Nov 18, 2001 | 11:01 AM
ftwflh's Avatar
I had to get my son a new atv and he is 10 but had been riding atv s and dirt bikes since he was 5.We had an Eton and i swore there would be no more Tiwaness quds around here.That left out most alll the new ones.We opted for a 125 Yamaha Breeze.It out performs all his buddies 90cc quads by a long shot.It does'nt have the greatest suspension But he is not raceing just trail ridding.But it is a 4 stroke with lights and automatic with reverse.Just letting you know there are mre than the youth quads that are good for kids.It is susposed to be for 16 up but it is way to small for that.Just a bit bigger than a badger.
Old Nov 27, 2001 | 12:03 PM
carjocky5150's Avatar
Well we started off with a e-ton 50 cc and it has been awesome. We took it to W.N.F. in the muddy hills and it was a champ. Also we just bought a T-rex 90 for $1600 and it is just as nice. In fact I am going to sell the 50 and buy another t-rex 90 for the other boy soon.
carjocky
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
AlotL1keVegas
Aug 18, 2015 09:38 PM
