CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
ds 650 swing arm swap
Old Nov 4, 2009 | 07:37 PM
vintageds's Avatar
Default ds 650 swing arm swap
will a 2007 aluminum swing arm bolt up to a 2000 ds 650 ? is every thing the same besides the length?
Old Nov 11, 2009 | 08:04 AM
justme23005's Avatar
Yup, except the piece that the rear caliper bolts to. its a little different
Old Nov 11, 2009 | 10:45 AM
TheStir's Avatar
Started riding ATVs in 1974!
The swing arm bushings are different. You will have to use the old style in the new arm.
I was able to use the caliper mount, it did rotate the caliper to the rear as the peg is higher on the newer arm.
You will also need to use newer spacers with the lower shock mount. I just flat ground my older ones.
I like the shorter arm for the dirt, but it did make it a little light on the front end for the sand. Main thing is saving 12Lbs over the older steel arm.
Old Nov 18, 2009 | 10:02 PM
vintageds's Avatar
thanks
fd24
Jan 16, 2019 08:59 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
austinwhitton
Aug 11, 2015 06:21 PM
Bell21
Jul 28, 2015 06:52 AM
