CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2012 renegade bogs down when started up, help!
Old Mar 7, 2013 | 09:56 AM
greenflame's Avatar
Default 2012 renegade bogs down when started up, help!
Hey my can-am renegade 500, when first started bogs down and dies when first started, note that it is really cold when im at. what could be the problem? could it be the gas ive put in it, it is farm gas
Old Mar 7, 2013 | 10:03 AM
Airb's Avatar
If its been sitting a while then the carb might be a little dirty. Try cleaning it or spraying some carb cleaner. Does it run with throttle? If so then you might need a richer pilot jet.
Old Mar 7, 2013 | 10:22 AM
greenflame's Avatar
no i run it every single day. it just started doing this yesterday, and its FI. so i dont know what could be wrong. i might run a little rubbing alcohol through the gas and them some octane booster, would that help?
Old Mar 7, 2013 | 10:40 AM
Airb's Avatar
That's very weird if it is fuel injected. I have never had idle/transition problems with an efi vehicle. I do not know if can am does this but Polaris has a sensor in the throttle mechanism by the throttle lever box to prevent a stuck throttle. This could be making contact and causing the atv to shut off, but I don't know if can am has this mechanism. It has happened to me before with a Polaris atv(carbureted).
Old Mar 7, 2013 | 10:42 AM
greenflame's Avatar
hmm wel i can just take it to my can-am dealer and have them check it out. thank you though!
MikeyBoyesq
Nov 27, 2020 02:44 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
1000gade
May 27, 2015 12:37 PM
