CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
wont start
Old Mar 14, 2016 | 09:08 AM
scootdaddy13's Avatar
Default wont start
my 01 ds 650 baja quit and oil is leaking out of the spark plug hole? help
Old Mar 14, 2016 | 10:17 AM
Fasteratv's Avatar
You could have a blown top end.....but, check oil level, I'm guessing it's very high and could be because of a leaky carb needle valve and leaked fuel into the crankcase via the piston rings. Get oil to correct level, remove spark plug, spray some brake cleaner in the spark plug hole, and turn the engine over a dozen times or so....let it sit for a half hour, check the crankcase ventilation and ensure free and clear, install a new spark plug........and try to start it.
serveyer
Mar 15, 2016 10:27 PM
razman_07
Mar 13, 2016 04:06 PM
Tom Latham
Mar 7, 2016 11:42 PM
lolslim
Mar 1, 2016 04:57 PM
MapleNeil
Feb 15, 2016 05:22 PM
