which full pipe for 03' baja
i'm looking at the mbrp, rwr, or trinity pipes for stock 03' baja, which one would you guys go with and why? thanks[img]i/expressions/face-icon-small-happy.gif[/img]
i heard the rwr pipe gets dented on jumps, and the trinity is boasting an extra 10hp from stock, whatta you think?
I'd say the RWR gives the most and best power (and wicked sound) but it is pretty big and can get dented on your caliper if you bottom out. I have the Wood pipe and I love it, although I haven't done much jumping since I got it 2 weeks ago.
Hope this helps.
TyreSpinner
Hope this helps.
TyreSpinner
I have the MBRP. Nice power and the stainless steel construction is a plus. It has a mount for the heat shield and there customer service is really good. When I ordered mine it shiped out that same day!! I do have the full race system and it is a little loud but it sounds awsome!! The fit and finish is really good for a aftermarket pipe and I put a 3/4 in spacer between where it mounts to the frame and the clamp just ot be safe on those big jumps. I really don't see a problem with the pipe hitting though it looks to have plenty or clearance. Whatever one you chose they are all good pipes and make good power and I am sure you will be happy with the performance gains.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
greg86hd
Sep 16, 2015 12:32 AM
