Another chain question.
Old Jun 6, 2003 | 04:40 PM
  #31
TyreSpinner's Avatar
Default Another chain question.
If I was to go 15-41, would that work with the stock chain?? taking off a link i mean..
Thanks
Old Jun 6, 2003 | 04:55 PM
  #32
1BigDSRider's Avatar
Tyre hopefully someone will correct me if I'm wrong. But stock gearing is 16/40. IF you run the 15/41. It will still be the same gearing as stock. If you do run the 15/41 you shouldn't have to take any links out. Going from a 16 stock to 15 in front would drop your gearing and give you more bottom end and you would have to remove a link if you stayed with the stock 40 in rear. Do a search on gearing or sprockets and there are a bunch post for this question.
Old Jun 6, 2003 | 05:13 PM
  #33
Umm...
going down on the front gives more bottom...and going up on the back gives you more bottom too...
Correct me if I'm wrong..
Old Jun 6, 2003 | 07:39 PM
  #34
They work opposite of each other. Going down in front gives more bottom end. Going up in back gives more bottom end.
Old Jun 6, 2003 | 08:09 PM
  #35
Yea, lol, exactly what I said.
So 15/41 would be a lot shorter than stock gearing. Shorter than 15/40, but not as short as 14/40.
Back to my Q, would I need to remove a link or something if I was to use 15/41 set-up??.
Thanks
Old Jun 6, 2003 | 09:41 PM
  #36
No the 15/41 would the same size and gear ratio as the 16/40 combo. Because you would be smaller in front and larger in rear making them =. Sorry about the other post read it wrong. IF you wanted shorter than you would need to go 15/39 and then you would take a link out. If you go down one size tooth in front its like going up 3 size teeth in the rear.
Old Jun 6, 2003 | 09:59 PM
  #37
I don't want to sound like a smart @$$ or something. But I think your confused...or maybe I don't know what I'm talking about.
Click the link in my signature that goes to my website. Then click ressources on the navigation bar on the left. That is a gearing calculator. Look at what it is with 16/40, then try it with 15/41 or whatever. You'll see that you will gain bottom-end (lose top-end). Unless the calculator is wrong....
Old Jun 6, 2003 | 10:07 PM
  #38
I think I confused myself on that one. It happens. Did you do the search for gearing.
Old Jun 7, 2003 | 12:00 AM
  #39
Yes, I've been reading previous articles on gearing. I'm pretty sure a 15/40 or 15/41 combo is what I'm looking for.
My current rear sprocket is worn, does that mean I absolutely need a new chain?? Or can I keep mine and replace both sprockets????
Thanks
Old Jun 7, 2003 | 12:12 PM
  #40
You dont have to replace the chain. But I would highly recommend it.
