vortex rev limits
Old Jun 16, 2003 | 10:25 PM
Slowride's Avatar
Default vortex rev limits
Understand, these can be retuned by folks like MT Racing. But these are the ones shipped from Vortex. I'm trying to get dyno results of each as well. I will post them if I get them.
X10 Switch Position Switch Map Name Power Type Rev Limit RPM
POWER MAP 1 1 ds65x1t1.igc Performance Map 8,350
TRACTION MAP X10 2 ds65x1t2.igc Traction 8,350
TRACTION MAP X10 3 ds65x1t3.igc Traction 8,350
TRACTION MAP X10 4 ds65x1t4.igc Traction 8,350
TRACTION MAP X10 5 ds65x1t5.igc Linear Power 8,350
TRACTION MAP X10 6 ds65x1t6.igc Linear Power 8,350
TRACTION MAP X10 7 ds65x1t7.igc Performance Map 8,350
TRACTION MAP X10 8 ds65x1t8.igc Standard Map 8,100
TRACTION MAP X10 9 ds65x1t9.igc Standard Map 8,400
TRACTION MAP X10 0 ds65x1t0.igc Standard Map 8,600
Old Jun 16, 2003 | 11:59 PM
PureIntimidation's Avatar
Hmm, could you explain this too me...I thought the box was supposed to take away the rev limiter. Im asking this, because I just ordered this box. How does it compare to the other cdi's, do you know? Just curious to know that im not forking out money for something i shouldn't have. Also, if you dont mind..how much did you give for it?
thanx
Old Jun 17, 2003 | 12:31 AM
ironrod's Avatar
Ok, I dont want to get in trouble for posting this info - so please dont get me in trouble folks! This is what a certain person posted in a certain place after they got thier CDI from a somone else ... This is info that was packaged with his Baja CDI from Vortex.
Handle Bar Switch: Power
CDI Position switch 1
Performance Map (advanced Timing)
Handle Bar Switch: Traction
CDI Position Switch 2
Traction (retarded Timing)
CDI Position Switch 3
CDI Position Switch 4
CDI Position Switch 5
Linear Power (Even Power Curve & Timing)
CDI Position Switch 6
CDI Position Switch 7
Performance Map
CDI Position Switch 8
Standard Map with Rev Limit at 8100 RPM
Standard Map with Rev Limit at 8400 RPM
Standard Map with Rev Limit at 8600 RPM
Old Jun 17, 2003 | 01:32 AM
DuneDevil's Avatar
Depending on were you purchased the Vortex from, they will program it to YOUR NEEDS.
If you don't want the limiter, tell them and they will remove it.
If you want the limiter at 10,000 or what ever, you tell them and they will program it at the limit that you want.
If you want a super high curve for alcohol, tell them and they will program it for you.
This CDI box is completely programable. It is up to the place that you purchased it to program it for you.
DuneDevil
Old Jun 17, 2003 | 01:35 AM
ironrod's Avatar
I think we were looking for clarification on how the box comes programmed. The (ahem) distributor will program them, but I was kind of curious to find out what they came with. Perhaps they have not all been the same from Australia. I guess its a good thing they can be re-programmed!
Old Jun 17, 2003 | 07:53 AM
So they CAN be reprogramed...sweet. Where would one go to do that? And what do you all think would be a good place to set the limiter?
I ask this, cuz my wife just bought me some goodies for the bike for fathers day and she was not asked for a preference on the vortex box.
Old Jun 17, 2003 | 09:19 AM
ironrod's Avatar
Personally, I would like the Rev Limit set at around 9300 which would suit my motor mods. Wherever you purchased them should be able to send them back to the USA distributor for reprogramming. This holds true with everybody I know that sells them.
Old Jun 17, 2003 | 10:40 AM
DCryder's Avatar
What is the price? I just got a RWR cdi 2 weeks ago and do not like having the limiter. I dirt drag and when I shift at 7500 it revs to 9500 no matter how fast I shift. The 8200 or so would be perfect. Thinking very seriously about selling the RWR!
Old Jun 17, 2003 | 09:44 PM
Slowride's Avatar
My numbers are from richard@vortexcdi.com
As I said in the opening of this post, it can be tuned to your hearts content from stateside folks.
I received the same sheet of paper and inquired about the actual rev limits, since nobody had specifics.
I also am dying to see the dyno curves if I get them.
I personnaly would have liked positions 8, 9, and 0 set with the performance map and rev limits of 8,500, 9,500 and 10,500 respectively before it was sent to me.
I love my vortex.
jbt
Old Jun 17, 2003 | 10:11 PM
ironrod's Avatar
Yes, those numbers would be very good. I'd like to see them sent out that way from Aus.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
