Question about how much I will gain if..........
#21
your carb has a butterfly that is durect mounted to the cable . that gives you your true throttle the slide is there as a sort of backup throttle plate to smooth the transition(the stumble that the 45 has w/o the acc. pump). I had my slide sticking at half throttle last year on the ice , but since the butterfly is there you can let off the gas and the engine will come back down to idle.
#22
#24
I should get a big gain if I take off the lid and snorkels right? I am using a TM45 that seems to want to stay rich...
I currently only have K&N in the box without the Outerware..but I'm going to order the outerware in a few days.
Should this make a difference??
Quadzilla Heritage
09-25-2015 01:39 PM
