Jetting Help
Old 06-25-2003, 06:44 PM
racerx5x5's Avatar
Default Jetting Help
It is the one under the big cap on the top of the carb. It's like 4"or 5", I cut four coils and am going to cut two more off. I heard it's the magic #
Old 06-25-2003, 06:47 PM
BigBoyToyz's Avatar
So cut the coils and dont re-stretch the spring? Wont this end up letting the slide rise at idle causing a lean condition?
Old 06-25-2003, 06:59 PM
racerx5x5's Avatar
It just lets it come up faster. The jets control your lean and rich condition.
Old 06-25-2003, 07:10 PM
BigBoyToyz's Avatar
So when you jet you only ever change the main jet not the (pilot) ? Isnt the main for mid to upper? what jet does low end?
  #15
Old 06-25-2003, 07:23 PM
BigBoyToyz's Avatar
Also how do you get the needle out of the slide setup? I know dumb question im sure but id rather ask then break something [img]i/expressions/face-icon-small-smile.gif[/img]
  #16
Old 06-25-2003, 07:33 PM
RoughRider01's Avatar
The needle kicks in around 1/8 throttle to 3/4 throttle.... the main controls 3/8 throttle and up.
So you got the top of the carb off right now? I just rejetted today and i believe mine just slid out. I think i had to push on the pointy part and it came out.. hold your hand over the opposite side or else your spring and other stuff will fly out.
Steve
  #17
Old 06-25-2003, 08:13 PM
BigBoyToyz's Avatar
If you look on the topside of where the needle is the seems to be a plastic cover...that just slides out?
  #18
Old 06-25-2003, 08:19 PM
Youre talking about the piece that the big spring goes in, it also has that rubber collar (take that thing off too, it just gets in the way when changing the needle)on the top too? Mine slid right out, and when i changed the needle it slid right back in. I never had to unscrew anything, so im thinking that i just pulled it out gently.
  #19
Old 06-26-2003, 03:18 PM
BigBoyToyz's Avatar
On the jet kit...is it safe to assume that the thick plastic washer under needle clip gets used on new kit?
  #20
Old 06-26-2003, 03:21 PM
I asked the same question yesterday and i was told that it gets used again. So thats what i did.
Quick Reply: Jetting Help
