450 CAMS
Old Jul 2, 2003 | 06:13 PM
FinalClimax's Avatar
Default 450 CAMS
I will be running the 11.5:1 piston. Are you saying I should go to a 12.5:1. I really wanted to stay with regular gas.
Old Jul 3, 2003 | 01:39 AM
Hurycne's Avatar
Default 450 CAMS
with the higher compression the hp will be more evident. It will have a good seat of the pants feel. You can buy a torco additive if you feel that the race gas is to pricey or not available.
Old Jul 3, 2003 | 01:47 AM
lilnotts's Avatar
Default 450 CAMS
Hurycne, wats this torco additive your talking about?
Old Jul 3, 2003 | 01:54 AM
Hurycne's Avatar
Default 450 CAMS
mach series accelerator....says that it can turn premium pump up to 107 octane. 107 for 5 gallons and 104 for 10 gallons.
Old Jul 3, 2003 | 01:56 AM
  #15
SANDMAN430's Avatar
Default 450 CAMS
it's not like you would have to run all race gas but a slight mix i've been hearing around a 100 mix
Old Jul 3, 2003 | 02:12 AM
  #16
Hurycne's Avatar
Default 450 CAMS
It is a cheap alternative to 5 dollar a gallon fuel
Old Jul 3, 2003 | 02:17 AM
  #17
SANDMAN430's Avatar
Default 450 CAMS
does it work good ? i was planning on buying a barrel of 120 and going 3-120 and 2 pump it should make for a 109 mix. the barrel is 231 that makes the race 4.20 a gallon, but still not like pump gas.
Old Jul 3, 2003 | 02:19 AM
  #18
Hurycne's Avatar
Default 450 CAMS
I used it before I switched to Alcohol and didnt have any problems
Old Jul 3, 2003 | 05:17 AM
  #19
ThePunisher's Avatar
Default 450 CAMS
Anythng over 105 octane is overkill! You can run Pump 100 octane on a 12:5:1 ratio just fine. If i were you Sandman I would run something like VP Red.
Old Jul 3, 2003 | 08:35 AM
  #20
SANDMAN430's Avatar
Default 450 CAMS
how do you figure that octane with compression besides riding and hearing the ping?
