sprocket teeth????
Old 07-29-2003, 01:17 AM
BROWN650's Avatar
Default sprocket teeth????
I was wondering how many teeth i should have on the front sprocket running 22' ten paddle haulers?
Old 07-29-2003, 02:16 AM
ironrod's Avatar
Do you want your gearing to match the stock gearing with the 22" tires?
Old 07-29-2003, 02:17 AM
BROWN650's Avatar
i cannot pull 22' with stock on topend
Old 07-29-2003, 02:24 AM
ironrod's Avatar
Use the Gearing Calculator
Old 07-29-2003, 02:26 AM
ironrod's Avatar
Looks like you could have a 42 in the rear with a 15 in front. or for lower gearing, you could just go with a 14 in the front.
Old 07-29-2003, 09:53 AM
SANDMAN430's Avatar
it will be hard to pull those 10 paddle stock, try the 14 that should work. you will want to consider some clutch springs soon.
Old 07-29-2003, 10:55 AM
BillDS650's Avatar
Your problem are the ten paddles haulers. They over power your engine get a set of eight paddles
Old 07-29-2003, 12:04 PM
ironrod's Avatar
Tru dat
Old 07-29-2003, 12:11 PM
SANDMAN430's Avatar
or you could keep the tires and work the engine[img]i/expressions/face-icon-small-smile.gif[/img]
Old 07-29-2003, 12:57 PM
hinglbyds's Avatar
My DS is a woods stage 1, stock gearing (16/40) and 22-11-10 10 paddle extreem haulers. On the beach in Mexico I averaged 69mph in two runs in oppisite directions.
helpfull I hope
Quick Reply: sprocket teeth????
