597cc twin cylinder 2-stroke Rotax!!
Old Aug 6, 2003 | 05:02 PM
Overkill's Avatar
Default 597cc twin cylinder 2-stroke Rotax!!
When I was at Dunefest I saw a one seater sand buggy with a 597cc twin cylinder 2-stroke Rotax engine in it. You can look at it if you go to www.drakart.com. The motor produces 110hp @ 8200 [img]i/expressions/face-icon-small-happy.gif[/img]!! It is set up to work with a CVT transmission, but with that much power, who cares about a little thing like gears! It would sure be a Banshee killer. I don't know which sled it came out of, but it would be interesting to see someone adapt it to a DS... It would be like a V-Force on 'roids!
Old Aug 6, 2003 | 05:13 PM
BansheeMan98's Avatar
It is a common occurance to see a banshee 350 produce around 100hp. I have seen 500cc banshees produce close to 150hp. Although rare, I have seen a turbo banshee produce almost 200hp. So a 597cc producing 110hp is not as impressive as if first seems. Just
my 0.02
BM98
Old Aug 6, 2003 | 05:18 PM
racerx5x5's Avatar
But it is, Because it will run 5 times as long[img]i/expressions/face-icon-small-happy.gif[/img] Rotax Rocks!!!!!!!!!!!!!
Old Aug 6, 2003 | 05:19 PM
lilnotts's Avatar
its probably out of a mxz600, my bros got a 700 and it produces 125hp stock,
Old Aug 6, 2003 | 05:31 PM
bbertram's Avatar
Its just a sled motor, get a 1000cc cat.....then you will be making power.
Old Aug 6, 2003 | 05:38 PM
lilnotts's Avatar
i thought they stopped makin the 1000cc triple? changed it 2 a 900cc twin cuz it made more power, ionno, i'd prolly get the 800H.O. rotax motor
Old Aug 6, 2003 | 05:41 PM
PUSHINTHELIMIT's Avatar
Any of the new 800 motors make more power than the 1000cc cat motors anyway...... Not to mention how UNRELIABLE a 1000cc cat is....
Old Aug 6, 2003 | 05:43 PM
lilnotts's Avatar
ya even the old mach z's would pull away from thundercats
Old Aug 6, 2003 | 08:25 PM
AgressiveRider's Avatar
The old 1000 triple made 172hp. Most 800s today make about 140-150hp.
Old Aug 6, 2003 | 08:30 PM
Then why are the 800's just as fast or faster? Don't tell me that the cats were faster because they aren't.. I do know the 1000cc cat weighs a ton....
