what JET kit to buy?
Old Aug 17, 2003 | 12:57 PM
SANDMAN430's Avatar
Default what JET kit to buy?
i'm not sure about that spring cuttting, we all run some of the same machines around here and we share all our secerts with each other and i don't see that spring helping any.
Old Aug 17, 2003 | 01:03 PM
PUSHINTHELIMIT's Avatar
Well I also cut my slide spring and it did help out throttle responce BUT it caused me to run way rich!! I'm down to a 165 DJ main and I'm still running rich from 1/4 throttle to full throttle so I think I will be going back to an untampered spring.... Drilling the vacume ports I believe helped quite a bit though...
Old Aug 17, 2003 | 01:17 PM
TyreSpinner's Avatar
I'd say search on E-Bay for a used TM carb...(No, not a lectron [img]i/expressions/face-icon-small-smile.gif[/img], first off you probably won't find any)...TM carbs are VERY popular on Harley's and you can probably get one cheap. Then all you'll need is to rejet and get a soft throttle spring from RWR if you want to use thumb... You will really see a difference in performance over the stock carb...Dynoes have showed around 3-5 HP increase over stock...
Other than that, don't waste your money on a jet kit..[img]i/expressions/face-icon-small-smile.gif[/img]
<------- Richard Simmons is back...Yea!
Old Aug 17, 2003 | 01:52 PM
ATVMX's Avatar
OH GOD!!!!
