2001 DS650 FAN PROBLEMS
Old Aug 20, 2003 | 11:10 AM
  #21
SLICKER011's Avatar
Default 2001 DS650 FAN PROBLEMS
what about cdi boxes I still have the factory one in mine...Does the ron woods cdi increase the power that much to pay the 300.00
Old Aug 20, 2003 | 11:30 AM
  #22
ironrod's Avatar
There are several CDI boxes out for the DS now. All of them are good.
1) Big Gun - Increase the rev limit by 1000 rpm and sells for around $230
2) Ron Wood Racing - No rev limit and sells for around $270-$300.
3) Alba - Same as the Ron Wood Racing CDI $300.
4) Graydon Proline - I think the Rev Limit is around 9500 on thiers
5) Vortex - $350-$400 - has ten curves all with various rev limits
I've got my old Ron Wood Racing one on EBAY righ now.
Old Aug 20, 2003 | 11:44 AM
  #23
ironrod's Avatar
AZ - Check your email.
Old Aug 20, 2003 | 03:31 PM
  #24
SLICKER011's Avatar
can anyone show me a picture of how the 2003 ds fans are mounted...
Old Aug 20, 2003 | 03:39 PM
  #25
ironrod's Avatar
Here's the pic.
Old Aug 20, 2003 | 08:44 PM
  #26
Oldmanracing's Avatar
You can buy the fan directly from Spal.
Go to your dealer and buy the kit for mounting the fan on rubber bushings.
Will require doing some spot welding.
Installed fan with rubber bushings and have gone almost 2 years with no failure.
Also recently installed a inline cooler, and reduced fan running to only when hard in a tight woods.
Old Aug 20, 2003 | 09:22 PM
  #27
ScoobyDFW's Avatar
i was told not to remove the thermostat because because it would lower the pressure in the cooling system which increases the chance of air pockets forming, which can create cylinder hot spots.
Old Aug 21, 2003 | 05:38 PM
  #28
SLICKER011's Avatar
DOES THE CDI MAKE A BIG DIFFERENCE IN POWER CURVE....
Old Aug 21, 2003 | 05:39 PM
  #29
SLICKER011's Avatar
THANKS FOR THE PIC....
Old Aug 21, 2003 | 05:41 PM
  #30
SLICKER011's Avatar
SPAL??? WHO ARE THEY...AND HOW DO I CONTACT THEM...OFFROAD SUPPLY SAID A FAN WOULD RUN 64.00 IS THIS ABOUT RIGHT...THANKS
