Topend Break-in w/Alcohol
It probably could be done Scooby but I wouldn't recommend it. Alchohol tends to get past your rings in the first place! Just think how bad it would be with a fresh set of rings and a new Cylinder! [img]i/expressions/face-icon-small-shocked.gif[/img] Just break it in with some 110 and then run the alchohol, better to be safe than sorry.[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
I also do hot rod garden tractor pulling and I run alcohol. The engine goes from totally fresh to wide open with no break in, I just change the oil after I get back to the shop. They usually last for 2 years before I re-ring and put in new rod inserts.
Oh and they also do not have an air filter.
disclaimer: while all the above statement is true this kind of performance is this individules own experiance you should not expect your experiance to be as fortunate. The above statement is no warranty, expressed implied or otherwise, to any equipment or part that might be able to be classified as pertainable to this thred. Author of this thred is not responsible. [img]i/expressions/face-icon-small-happy.gif[/img]. . . . . . . . . . but is alot of fun.
Cub Cadet with 16horse kohler bored to 4" , 3 15/16 Stroker crank, 539 lift cam and 57 1/2 mm S&S carb. on alcohol
Sears gone mad: Sears lt 10 hood grill and dash on homemade frame with a 1000 kaw ninja with big bore kit stroker dif carbs and ported and polished, tuned exhaust with equalizer pipe to keep back pressure equal on 110 racing gas [img]i/expressions/face-icon-small-happy.gif[/img]
Originally posted by: airraptor
gosh damn a 53mm carb on a lawn mower lol thats huge most guys here only 45mm singles. i bet that mower can cut some grass and haul some as$
We build em right and wind em tight [img]i/expressions/face-icon-small-happy.gif[/img]
If ya ain't goin big then wear a wig
