aluminum frame ds request to build
Old Aug 22, 2003 | 12:02 AM
bbertram's Avatar
Default aluminum frame ds request to build
Let me suggest titanium, strong and lighter weight due to less material used.
Old Aug 22, 2003 | 12:18 AM
Entomber's Avatar
The cost of a titanium frame would be outrageous. An aluminum sub-frame along with an aluminum oil tank would be nice. Upper a-arms and swing arm in alumin will also further reduce the weight. DS wet 430-450 pounds is that attainable?
DS is overengineered. Lots of weight can be cut here and there. The two brackets that hold the motor up front are rather heavy.
Old Aug 22, 2003 | 12:19 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Does anyone know the approximate weight of the DS frame.
AZSAND, check and see if you have a motor in that DS.
Old Aug 22, 2003 | 12:24 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Well as a matter of fact there is no motor in my bike right now but just the same with the motor it only weighs in at 402 this year at FSWIII it will come in at 350 ish(thats with out my fat azz on it) but trust me we will go low!!
Old Aug 22, 2003 | 04:12 AM
  #15
mystereid's Avatar
AZ, I believe ya. Can you enlighten us as to your larger areas of weight reduction or are those secret?
Old Aug 22, 2003 | 02:58 PM
  #16
AZSAND's Avatar
Here we go!!
Swing arm- alum tvi 10lbs
rad titanium axel with honda huds 13.5lbs
modified coustom sub frame 4.5lbs
coustom titanium sprockets front and back 1lb
titanium chain 3lbs
no front fenders 14lbs
cut race fenders in rear 2.5 lbs
tbr arms 4lbs
tbr steering stem 1.5 lb
tag alum bars 1lb
removed eal guards and brackets 5lbs
tripple buffs on all 4 corners 10lbs
Well im getting busy now i must run but i think your starting to get the pic [img]i/expressions/face-icon-small-wink.gif[/img] the bike scales at 402 with one gallon of fuel[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 22, 2003 | 03:20 PM
  #17
mystereid's Avatar
Thanks AZ. I've never heard of a Ti chain before, I would'nt even know where to look for one.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Elkaholic
Sep 6, 2015 02:44 PM
