sprocket hub???
I've got to add some info... or maybe help to clarify. It seems this is a huge topic this week!!
The sprocket hub will only come off once you have;
Either removed the collar on the left side and backed off the Rotor hub....
(Doing this allows you to move the Sprocket hub slightly... so you can get to the retaining ring and remove)
or
Remove the axle all together.
I'd remove the axle all together to make it easier.
Hmmm... I just re-read your post.
Go look at the "axle removal" thread.... It's much easier to understand, plus there's a link to pictures.... etc...etc.
"I'm just trying to make my 100posts!!!" hehheehhe
or
Originally posted by: DSWOLF
only thing now is to find me some bearrings.
I found my bearings to be pretty damn dry.
Since I didn't have time to buy new ones, and re-install.... I used a 60cc syringe full of some moly (water proof) grease and shot those bad boys like a horse. They should last me some time.... but I'm too going to order a new set, and the bearing tool for next time.
Glad you got it worked out.
