new turbo project for me!
Old Sep 3, 2003 | 01:15 AM
ScoobyDFW's Avatar
Default new turbo project for me!
i used to run aerocharger, but switched to garrett to run high boost reliably.
i now run an off-the-shelf GT15 (not ball bearing), .35 A/R turbine housing with 41mm wheel, .48 A/R compressor housing with 45mm wheel.
Old Sep 3, 2003 | 01:18 AM
AzRaptor's Avatar
Were you running the aerocharger or Garrett @ FSWII?
Old Sep 3, 2003 | 01:23 AM
ScoobyDFW's Avatar
aerocharger @ FSWII (with ceramic ball bearings going bad and clutch smoked)
Old Sep 3, 2003 | 01:27 AM
Majorecho's Avatar
Scooby ...what kind of lag are you getting with that combo?
Old Sep 3, 2003 | 01:30 AM
  #15
Hurycne's Avatar
hmmmmm
Old Sep 3, 2003 | 01:34 AM
  #16
ScoobyDFW's Avatar
the GT15 spools pretty fast when loaded. not quite like a ceramic ball bearing variable geometry turbo, but is adequate. the GT15 doesn't like if you load the motor at low RPM - it can bog and take a while to build boost. i rev to 7500RPM to launch and don't have a problem with spooling. i run a weak stock motor (8:1). i have removed the intercooler and large chrome pipes, reduced the size of the plenum, to reduce unnecessary volume for faster spooling.
Old Sep 3, 2003 | 01:37 AM
  #17
AzRaptor's Avatar
What else have you done to the engine, ie. headwork, cams, rod, etc... Or is it actually completely stock.
Old Sep 3, 2003 | 10:41 AM
  #18
Ds650RaCeR's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 3, 2003 | 12:03 PM
  #19
bigben's Avatar
Man, I wish I had the time and $$ for a turbo project. I think it's the way to go. I'm glad more people are trying it. I might have to go to FSW just to see how it turns out.
Old Sep 3, 2003 | 03:47 PM
  #20
Batoutahell's Avatar
Major, sounds like quite the project should be fun. Good luck and hope it all pans out.
Cant wait to see that thing running up the mtn.
Bat
