Won't Start :(
Old Oct 12, 2003 | 11:54 AM
marrtoo's Avatar
Default Won't Start :(
I don't know if this has happened to anyone else but it took me a long time to figure it out. I filled the gas tank up and kept filling it so "I could go longer". After I forced as much as I possibly could into it I started it to let it warm up. It ran for a few minutes then died and would not start or even try. I checked and it was getting spark and I knew it had fuel in the tank so I tapped the carb and still nothing. I ended up being pretty pi**y. I finally figured it out. The nose of the DS was facing a bit down hill and the gas went in the overflow and it ended up vaporlocking. I drained some of the gas and it ran great.
end of story. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 12, 2003 | 02:11 PM
dhughes2k's Avatar
How can you tell if the valves are burnt? The shims have black rings around them but they all have them and it looks pretty normal to me. Wouldn't rejetting only affect WOT and not starting? I haven't looked at anything yet because I am waiting for monday to get some new shims and see what happens. I'll post back when I get the valves adjusted and put back together. Thanks for the help so far[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 13, 2003 | 03:03 AM
Gashog's Avatar
The way to check if the valves are burned is to do a compression check. To see if you are running too lean, check the spark plugs to see if the color is white. Black means too rich. They should be light tan for the correct mixture.
Modifying your endcap affected the jetting at all throttle positions.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
