Carb theory
Old Oct 12, 2003 | 10:49 AM
BillDS650's Avatar
Default Carb theory
If you are going work on the stock carb this might help CV carb mods
Old Oct 12, 2003 | 10:50 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default Carb theory
Gashog, thanks for recomending those books, the last performance book I read was Smokey Yunicks Power secrets.
Old Oct 12, 2003 | 10:56 AM
mystereid's Avatar
Default Carb theory
BillDS650, thanks, I just found that the other day using Google. The thing I picked up on is they write about opening only one hole up in the carb slide where the Mikuni has two air bleeds.
Old Oct 12, 2003 | 03:55 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Default Carb theory
Although it works sometimes, I have found that racing against a buddy etc. is the worst possible way to tell if you are making more horsepower. When I find as little as 2HP on the dyno I have to make suspension changes to put that power to the ground. Most of the time when I get to the track with more power I will be running the same et's as last time or a little slower. Then the process of tire pressure, wheelie bar heighth, shock compression and rebound etc. has to start all over again.
mystereid, why do you think its odd to make gains across the board with a bolt on. I personally would not own a product unless it made gains from idle to max rpm.
I run the air box with a stock carb only. I have never been beat by someone running a stock carb with out the air box. I agree that the air box restricts flow but the vacuum operated slide will not open with out it, period. I could put another 40hrs of dyno testing into it and probably get more power with the box removed but the tracks I race at require that it be on, thats why I tested it that way. My results make impressive power with a stock carb and I have shared those results for one reason; people are wasting their hard earned money on things that dont work. I think I proved at Aledo that a stock bike tuned right is BRUTALLY FAST.
MrHorsepower
Old Oct 12, 2003 | 05:55 PM
  #15
Hightower's Avatar
Default Carb theory
Now come on, I have personally seen DS's wearing stock carb w/ carb mount filter in motion, and have also been beaten by them. I'm not saying carb mount is better mind you, like i said before I haven't dicked with it, but it does work just fine.
Old Oct 12, 2003 | 07:07 PM
  #16
Default Carb theory
When I say it will not open I'm speaking in a performance manner. In other words it will not open 100% and stay open at full throttle. It fluctuates at high rpm because of vacuum signal loss and reversion. Anyone that has ever been on the dyno could not overlook this as the dyno sheet has severe spikes in the power curve.
MrHorsepower
Old Oct 12, 2003 | 07:31 PM
  #17
Hightower's Avatar
Default Carb theory
I see, my bad, I also overlooked your very next sentence after that one which would've explained too [img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 12, 2003 | 08:05 PM
  #18
Default Carb theory
Cool !!
Old Oct 12, 2003 | 08:51 PM
  #19
mystereid's Avatar
Default Carb theory
MisterHP, I agree that the fluttering of the vacuum slide is the CV carbs biggest problem. What measures did you try to limit this? Did you try routing the vent to into the filter? How about restricting the vent orafice. Did you try the slide bleed hole drill and spring tricks? If you dyno tested every option then there is no reason for me to procede.
Side by side racing is the best I can do without a dyno. Racing I guy I've know for 25 years and raced a thousand times, with an identical bike works a whole lot better than trying a change out in my back yard.
Uphill sand drags seem pretty forgiving for chassis set up. Beach racing on flat sand also works pretty well because after the hole shot you can tell easily if the guy next to you is gaining or losing.
Old Oct 12, 2003 | 10:21 PM
  #20
SANDMAN430's Avatar
Default Carb theory
i kind of agree with mystereid, the sand decides who is faster pretty quick. but if i could i'd get a dyno for the garage, but i just can't bring myself to get rid of the gym set up that i paid to much for.
