not running right?
Old Nov 3, 2003 | 06:06 PM
marrtoo's Avatar
Default not running right?
Forgot, Change your oil. and while at it it would be a good idea to check the screen in the bottom of the oil res.
Marrtoo
Old Nov 3, 2003 | 10:54 PM
poacher's Avatar
i think i fixed it i havent got to try it out yet, but i took it to work so i could work on it after i got done and the 1st thing i did was change the oil then i took the carb off and there was a big chunk of dirt in the main jet so it was leaning out and was no fuel to burn for the top end id say, but i went down it to a 185 with lid on and my modded stock exhaust also the uni filter with the 6 little uni vents it ran great in the garage for 10 mins and it would have sputtered out by then before but, ill do a plug check when i get it out. also there was nothing on my oil drain plugs either so im think im set i do think it was a little rich, i put new plugs in also, thank you everyone for all your help i didnt know where to start ive had a other machines my last one was a raptor which was a good mach also but i had to try the big ds ive so much about and ill say im very satisfied with it, its very stable, go`s like a raped ape, and they wheelie awsome also, thanks again guys.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
