guys with toy haulers/travel trailers... please help me chose a generator size for the dune camping trips
Old Nov 7, 2003 | 09:42 PM
sixsixT's Avatar
Default guys with toy haulers/travel trailers... please help me chose a generator size for the dune camping trips
Originally posted by: raptor03
I picked mine up at sears and it worked great,and it's lite and small, if you put it on the opposite side of your trailer you dont even know it's there...
I knew it was there.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Nov 7, 2003 | 09:49 PM
Gaskett's Avatar
Just add up the amperage draw on the equipment you'll use and multiply by 120, that will give you watts. Then choose the generator for that rating.
Quick info
5500watts is 45.8amps
4500watts is 37.5amps
3500watts is 29.1amps
2500watts is 20.8amps
You'll want to flick the switch on the high current items first, because they will draw a larger start up current. Then the equipment will draw back to it's operating current. This way you won't overload the generator and knock it off-line.
I have a 5500 continous Honda powered, it's a little too much for what I need, but I always plan for the worst case scenario.
Good luck,
Glenn
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
traumajunkie
Jul 5, 2015 03:03 PM
yambam13
Jul 4, 2015 01:49 PM
