ron woods pipe produce good power?
Old Nov 10, 2003 | 11:27 PM
jaws03's Avatar
Default ron woods pipe produce good power?
i can only get slip on for my ds and i was wondering about the ron woods slip on its 260 dollars u get the muffler and clamp is that all ill need for it to fit to the stock header and is it loud
Old Nov 10, 2003 | 11:29 PM
SANDMAN430's Avatar
it doesn't work that way you have to buy the whole pipe with the woods.
Old Nov 10, 2003 | 11:31 PM
jaws03's Avatar
on the site it has the complet system and then the megaphone silencer and clamp for 260 then the mid section seperate and then the headers i though i could just buy the silencer and clamp buy its self
Old Dec 4, 2003 | 06:07 PM
mustang1274's Avatar
hey Jaws,
I thought the same thing. So I bought just the slip on. Much to my surprise it wouldn't fit. The RWR pipe doesn't have the same kind of connection at the header. So what I did was took my stock exhaust down to a muffler shot had them cut off the end that fits into the header and weld it up on the woods exhaust. Worked great for me.
Old Dec 4, 2003 | 06:30 PM
TyreSpinner's Avatar
Just buy the Wood headers. They are the best-flowing headers out there. Go big or go home [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 4, 2003 | 08:37 PM
BajaMark's Avatar
Before you buy a pipe, of ANY kind, try this.
Remove your stock end cap
Carefully cut the two 1/4" bars and the screen, as close to the inside of the end cap as possible.
Remove the screen assembly.
Cut off the reducer pipes which are welded inside of the end pipes.
Reinstall the screen and weld the 1/4" brackets back in place. Spark legal still.
This gives you more flow...But not to much like aftermarket pipes do.
Repack the pipe with FMF glass..Do this real good and tight.
Install a Mukini 190 main, K&N filter w/ outerware, remove air box lid.
You will now out preform any pipe on the market!!!! And it is FREE!
Old Dec 4, 2003 | 09:38 PM
ironrod's Avatar
Replacement part only - Ron Wood Does not offer a slip on pipe - what Sandman said!
Old Dec 4, 2003 | 10:03 PM
burglett's Avatar
i have a complete ron woods that has a small hole n the headpipe where the heat shield bolts up. The stud broke off and left a hole all u have to do is have it welded back up. Great power but im wanting to go back stock beacause of noise
Old Aug 9, 2004 | 10:06 PM
BomberX's Avatar
I highly reccomend a fmf titanium system for anyone concerned with noise and weight. i shaved 8.9 pounds off my ds compared to stock with the ti system and i have the option of inserting a quiet core/spark arrestor for ohv parks and national forest and can take the quiet core out in 2 minutes when im at the desert.
Old Aug 9, 2004 | 10:37 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Ron woods pipes are a great pipe, one of the best IMO. other than a drag pipe.
