no spark?
Old Nov 11, 2003 | 03:02 PM
tippxp's Avatar
Default no spark?
my quad turns over but i am not getting any spark, where should i start to check?
Old Nov 11, 2003 | 03:05 PM
buttfungus's Avatar
Default no spark?
Is your quad stock? check your kill switch first then cdi box and the electrical connections to and from your coils.
Old Nov 11, 2003 | 03:11 PM
ScoobyDFW's Avatar
Default no spark?
check fuses.
check for loose wire at coils.
Old Nov 11, 2003 | 03:55 PM
tippxp's Avatar
Default no spark?
my quad is not stock, woods cdi box, just rebuilt motor
i checked fuses and made sure i had good grounds
Old Nov 11, 2003 | 05:09 PM
ScoobyDFW's Avatar
Default no spark?
if frame was painted, double check ALL grounds. coils themselves must be grounded good.
cdi needs 12 volts, probably getting it assuming neutral and oil/coolant lights are working.
there is also the 2 wire magnetic pickup trigger. check connector.
if you still have the stock CDI try that.
Old Nov 11, 2003 | 05:24 PM
tippxp's Avatar
Default no spark?
i filed down all the powder coat at the grounds, my lights work, i can try the stock box
Old Nov 11, 2003 | 06:38 PM
buttfungus's Avatar
Default no spark?
Yep try the stock cdi box. A bad ground can make it hard on a cdi.
Old Nov 21, 2003 | 03:13 PM
tippxp's Avatar
Default no spark?
tried cdi that was not it anwhere else to check?
Old Nov 21, 2003 | 03:38 PM
biggerisbetter's Avatar
Default no spark?
Under the fuel tank is where the pick up sensor wires connects the coil wires. Its a big white plug.(i believe) also did you mess with the adjustment on the pick-up sensor on the flywheel at all?
Also make sure you Rectifier is plugged in good.
BIgger.
Old Nov 21, 2003 | 03:40 PM
CR724's Avatar
Default no spark?
Check your wires from the stator. I had a mouse chew through my wires once. My bike would turn over, but it wouldn't start.
