43 tooth sprocket. Which one?
Old Nov 28, 2003 | 03:04 PM
JMAC650's Avatar
Default 43 tooth sprocket. Which one?
I am running 22 ITP XCT's in the rear and want to go with a 43 rear sprocket. I need to know what is the best one out there? Also should I run steel or alum, and what are the benifits of either?
Old Nov 28, 2003 | 03:12 PM
gnd111's Avatar
Aluminum should be fine -- some 120hp cycles use them...
Old Nov 28, 2003 | 03:26 PM
JMAC650's Avatar
Also what do you guys think of a 15 tooth front sprocket? I heard that a smaller front sprocket is hard on the chain. Also I looked on another website and I can get closer to the stock gearing with the 15-41 combo with 22's.
Old Nov 28, 2003 | 03:55 PM
Hillbilly720's Avatar
Just a matter of personal preference but I prefer 20's with a 17 front or 22's with stock gearing. Spreads out each gear & gives a better top speed, also hooks up better reducing wheel spin. Even with the taller gearing I find myself always looking for 6th gear. Like I said, just a matter of personal preference. 22's with a 17 sprocket is really nice but I also have the motor to pull this garing, not sure what you motor setup is...
Old Nov 28, 2003 | 06:22 PM
SANDMAN430's Avatar
stay with a 42nd you won't have to change the chain. the aluminum works fine
Old Nov 28, 2003 | 07:54 PM
BillDS650's Avatar
I went down too 14/41 climb great but on long strights I was all was looking for 6th gear. I have gone to 15/40 now I due most on my duneing in 2nd and 3rd. I can stay in the gears longer befor I have to shift.
Old Nov 28, 2003 | 09:26 PM
JMAC650's Avatar
I am doing a swingarm conversion on my 04 to a 02. I already bought a new chain so I am cover on any gear selection I do. I think I am going with the 15-40 because I can't find a steel rear sprocket. everywhere I call says they only have alum, plus it's cheaper to stay with the stock rear. Thanks for all the help [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 30, 2003 | 09:57 AM
cop's Avatar
cop
If you put on 22's it has the same effect as going up one tooth in the front sprocket. If you want to go back to the stock gearing or as near it as possible it is ALOT easier to change the front sprocket down one in the front, to a 15T. Most of the drag racers I know of use a 15T with stock size tires for quicker acceleration @ 300ft. I have not heard of any ill effects from using a 15T on the chain.
Old Nov 30, 2003 | 10:15 AM
SANDMAN430's Avatar
maybe someone could put a link to the gear calulator on here for these guys to look at, depend on how you plan to run, on what gear with the 23" rear tires the 43 isn't so low but when i ran 20" it was like a tractor. if you are doing a set distance you should be hitting a max rpm as you cross the line. tire spin is another area to look at, it wil affect these things.
Old Nov 30, 2003 | 07:24 PM
ironrod's Avatar
Sorry about the loss of the Gearing calculator guys - I know I have visited at least 3 sites with good calculators - I just can't think of the addresses right now.
CALDS650
Jan 10, 2001 09:14 PM
THEXOTIC1
Jun 23, 2000 05:02 PM
426ex
May 20, 2000 02:41 PM
NVR2L8
Apr 22, 2000 03:13 PM
